Enterprise role-based access control for spreadsheets
Traditional spreadsheets are all-or-nothing when sharing. Grist lets you control access by table, column, row, and cell.
Why spreadsheets fail at access control
lock
Traditional spreadsheets (Excel, Google Sheets) offer only document-level permissions.
copy_all
Common workarounds (hiding columns, making copies, separating files) leads to insecure and fragmented data.
house
Compliance requirements (GDPR, HIPAA, SOC 2) demand granular data access control, or even self-hosting.
Role-based access control, row by row
What does RBAC in spreadsheets look like?
Table-level permissions
Hide entire tables from specific user groups.
Use case: Separating sensitive financial data (like budgets) while sharing operational data (like timelines).
Column-level permissions
Show/hide specific columns based on user role. Make certain columns read-only while others remain editable.
Use case: An HR system where employees update addresses but can’t see salary data.
Row-level permissions
Users see only rows relevant to their role, region, or assignment.
Use case: Sales teams see only their territory’s customers in a CRM, or a regional manager sees their region’s employees in an HR workflow.
Granular permission and user data
Conditions
Allow specific changes only when conditions are met (e.g., status is “approved by manager”).
Use case: Workflows where records move through approval stages.
User attributes
Map users to specific fields in a table within the document and reference those fields in access control rules.
Use case: Growing teams where role assignments change frequently. No manual rewriting of rules for each new user.
Link Keys
Generate secure, unique URLs that grant access to specific rows to external parties without login.
Use case: Collaborating with external vendors or subcontractors.
Define. Evaluate. Validate.
See data from other users’ perspectives to test access rules.
1
Reference user attributes and record data to define conditions with simplified Python syntax.
2
Rules are evaluated from top to bottom, with first-match logic.
3
Preview user roles with “View As” feature for quick validation.
check
Access rules enforced at API and database level, not just UI
check
Self-hosting option for complete data control
check
Export restrictions respect access rules (unlike column hiding)
check
Supports compliance requirements for data segregation (GDPR, HIPAA, etc.)
check
Open-source codebase allows security auditing
